So, here we are, after two years of work, it's finally here: The MacGyver Timeline. Or The MacGyver Chronicle, if you will. The idea was to sort out every event that ever took place in the MacVerse and put them chronologically on the timeline. I do have to say that sometimes that requiered rearranging the order of the episodes or else it wouldn't make sense. This is mostly during season 2, 3 and in small amount season 4 but the timeline mostly pulls itself straight. More is explained below in the introduction on how and why I made this timeline. The second post will be the table of contents and the third post will be our first flight through time. I hope you enjoy this ride, so fasten your seatbelts because we're in for a long one.
MacGyver's Timeline
Introduction
Two years ago I started on this timeline project because I was curious how MacGyver's day by day life would look like. Starting from the Pilot episode all the way to Trail To Doomsday, I worked out the entire timeline from the beginning of time throughout the centuries to see how everything in the MacGyver Universe affects him and everyone he has been in contact during his life.
Another reason why I started this project was after I read an article about Tommy Westphall. Tommy Westphall was a character on the show St. Elsewhere. An autistic boy from which is believed the entire St. Elsewhere storyline exist only in his head. Characters of St. Elsewhere have appeared on many other shows as well so it is believed those others shows also takes place inside the imagination of Tommy Westphall. The article then listed every show (over 400) that might take place inside Tommy Westphall's imagination. Some really old ones, some very new ones. I did notice MacGyver was not one of them. Pretty much every other show I know or have seen was in the list except MacGyver. Maybe that's what makes MacGyver so unique, because there is no connection with any other show at all. Yet, I did find a connection with two movie franchises that connects with a third. Which ones those are I'll reveal them when we get at their point in the timeline. I don't know if it's enough evidence to assume their universes run parallel with MacGyver but I think a date and a place is pretty solid stuff. Besides that I did not find any other connection at all with anything. So in that view MacGyver still is pretty unique.
And lastly and maybe even the most important reason was to straighten out all the continuity errors and to find out where all those college (girl)friends came from for example and where they fit in. I tried to smooth out everything as possible even if it meant bending a few things so it would fit anyway. But sometimes there are such obvious errors like MacGyver's yearbook in Jerico Games saying clearly 1968. If that's true a lot of other stuff no longer adds up. Who knows, maybe whatever I came up causes new inconsistencies but there was mostly plenty of room to juggle a bit with everything. So one way or another the pieces of the puzzle will fall in their places. It's just up to you to think what's acceptable. This is how I see it.
So in order to set this timeline, I'm going off on assumptions, theories, facts, legends and mentions that come straight from the show. I will assume that every assignment takes at least a week, unless he says otherwise. Flightplans are being calculated from LAX unless seen otherwise. I'll always try to conclude that the last scene takes place on the day of the airing, so that we sort of caught up with MacGyver's life and that everything else took place in the past week or the past few days. It might not always be the case, it might happen the last scene takes place after the day of the airing, it depends on how things turn out. With every episode that is set only during the day, I will assume that that day coincides with the airdate. There will be conflicts that shakes up the timeline so much an entire adjusting of the events is requiered but usually it pulls itself straight. MacGyver also seems to be working a lot on weekends.
